How do I know if using AptX HD with Bluetooth headphones?
Beantwortet-
Hi Mark
If your headphones use AptX-HD, then you are getting AptX-HD. BluOS Players will transmit at the highest level up to AptX-HD as negotiated by the headphones. If there was an indicator, that would be at your headphone's receive side.
Well, I just bought a Node X and have an ifi Go Blue which supports all codecs, including Aptx HD. Unfortunately I am getting only Aptx connection (announced by Go Blue) and there is no way to change anything on the Node X. When I stream to the NodeX, it goes via Aptx HD. Any idea how this can be fixed?
Hi Tamas,
Please send us a support ticket to support@bluesound.com and a member of our support team can assist you with your issue.
Thanks for #LivingHiFi0 -
Gibt es Neuigkeiten?
4 Kommentare
