Volume control enabled with a USB connection
    Hi Robert
    Check your external DAC specifications and information or their support channels. The two possible issues are your external DAC is not reporting back to the NODE correctly via USB handshaking OR your external DAC is not a DAC but a digital-to-digital converter meaning it is upsampling audio to a resolution higher than the source.
  • Robert WIlson
    My DAC is built into my Anthem STR preamp which has room correction that I believe does indeed upsample to a very high level for processing.
    Out of interest why does this cause the Node to enable volume control.
    That is a question for your DAC manufacturer.
