Compatible with dual power amps?
5 Kommentare
    Bjørn Ulvik
    Basically, your amplifer is overloading and/or overheating. Check your speaker cables.
    Also; if you switch L/R input on your Linn's, does the erratic behaviour follow?
  • Andy Thomson
    Hey, thanks for yoru reply!
    Wouldn't this have appeared in the diagnostic tests though? They ran it for hours without incident (apparently, though it's a very reputable firm, so willing to gove them the benefit of the doubt).
    Can do, what am I looking for? For added context, if I plug both speakers into the functioning amp, the whole system works perfectly, music plays without incident. Beautifully in fact, the DAC on the Node is incredible!
    I switched the L/R from the Node to the amps yesterday, and the problem stayed with the same amp. To me it seems logical the amp is the issue, but given the diagnostics from Linn, I'm hella confused!
    Linn tech support suggested I adjust the sensitivity on the amp, I've not tried this yet and is what prompted my question about the watts being delivered from the Node. I will give this a go when I get home later today but wanted to get some other ideas>
    Appreciate your help!
  • Bjørn Ulvik
    If one amplifier work with both speakers connected, you can rule out the Node and 1 amplifier.
    Max output of the Node should be abt. 2V - 2,1V. Input signal for maximum output of your amplifier is 870mV.
  • Andy Thomson
    Thanks again for your help.
    I actually haven't run the "faulty" amp as a single power amp, I intend to add that to my list of things to try.
    Assuming that works, where else could the fault lie? Something in the speakers themselves do you think?
  • Bjørn Ulvik
    If it were your speaker(s), it should behave erratic on both your amplifiers.
