Best connection, Bluesound Node 2 to Rega Elex R
    Analogue out to Input in using RCA connectors. Any connectors less than 6ft or 2m will be fine.
    Set your Amplifier to the maximum possible desired volume and then control the volume using the BluOS App - or - in the BluOS App Settings, Player, Audio set to FIXED output to set the NOD volume to 100% and let your Amp control the volume. Feel free to experiment and see what sounds right to you.
