Flex 2i Speaker drops out on tidal connect
I just got my Flex 2i and it works well with my bluesound 2i.
-With bluetooth they play in sync
-Radio streaming works no problem
As soon as I try something with tidal connect it drops out every 10 seconds for about 0.5 seconds. I set my router up with 1.1.1.1 and restarted both the bluesound and the flex.
The bluesound 2i I works perfectly with tidal connect but as soon as I add the flex, both drop out as above.
Any help would be great
worked! thanks a lot!!!!
