Node 2i not connecting to Apple Home
BeantwortetWhen I attempt to add my Node 2i to Apple Home I get message under Airplay-unable to connect to Node 2i. I want to add it to Home so I can use Siri with Node 2i. Airplay works perfectly otherwise. Please advise.
Bob J
- Open the Apple Home app and select "+" or Add Accessory
- Choose “Don’t Have a Code or Can’t Scan?”
- Hole your iPad or iPhone very close to or just over the Player
- Select the Bluesound 2i Player player you want to add
- Enter the same room name used when setting up your Player in the BluOS App
If problems persist, please select Help, Send Support Request in the App.
