Subwoofer Cross-over on USB connected RT-100
    Hi Christian
    The sub-woofer crossover setting is for when you do enable the sub, regardless of whether it's enabled or not. It is what frequencies are diverted away from the mains when you select subwoofer in your audio settings.
    You are not doing anything wrong.
