Bluesound Vault 2i to USB with Roon ROCK
    HI Tim
    The VAULT USB ports are for storage connections such as system backups or connecting content. The USB port is not an audio-out source.
    If you wish to use the DAC bypass features of the VAULT, you will have to use either optical or COAX out.
