Adjustable subwoofer crossover
BeantwortetHi, I'm new into BlueSound and I'm interested in buying a Powernode 2i HDMI. I haven't seen the device and software in action.
So I may ask if the subwoofer crossover frequency and the gain level can be adusted for using different active subwoofers witch shall be plugged into the "subwoofer out" connection on the rear side of the device?
The crossover of the SUBW OUT of the POWERNODE can be adjusted via the BluOS app but there is no gain adjustment.
Sam R.1 -
Oh ok, I see. The gain is no problem. It is more important to change the crossover frequency when you use a subwoofer with small speakers.
Thank you.
