Can I use my Bluesound Node 2i to listen to output via Analogue Audio and via Bluetooth Speaker simultaneously
    Hi Kate
    No - The Bluetooth transmission option is not designed for Bluetooth speakers but for Bluetooth headphones.
    If you want to listen to the same music in multiple locations at the same time, consider a Bluesound PULSE (any model) for that second room.
  • Kate Scott
    Ok great, and so if I have a pulse in that second room I can play music via the node to the hifi speakers and also the pulse simultaneously?
    That's the idea!
    Independently or simultaneously - the decision is yours and can be changed on the fly based on your mood.
