Node 2i - Optical Cable Replacement
BeantwortetI want to pass files through my Squeezebox Touch digitally and let the Node 2i to do the DAC operation.
Will this cable work with the Node 2i?
FosPower (3 Feet) 24K Gold Plated Toslink to Mini Toslink Digital Optical S/PDIF Audio Cable with Metal Connectors & Strain-Relief PVC Jacket
Mook-
The specifications appear to be fine.
Thanks, Tony.
