Gustard x16 and bluesound 2i
5 Kommentare
    If the file is not MQA - there is nothing to do. You do not have to toggle the switch - it simply lets the Bluesoudn NODE that if there is any MQA processing required, the external DAC is capable of performing it.
    Feel free to enjoy Amazon HD without worrying about settings.
  • Jacques finet
    So, Tony if i understand well theswitch external mqa dac must be always off ! Even if we have mqa files unfold with the x16 and volume 100% fixed.
    When do we have to put that switch on finally ?
    Thank you
    If your external DAC supports MQA, enable the switch. If it doesn't, don't.
    Then leave the switch as is. Please see this Help Centre Article for more details;
    https://support1.bluesound.com/hc/en-us/articles/115006191908
  • Jacques finet
    Tony, thank you but I giveup. Some threads say exactly the contrary. What i check, When i listen to mqa files, if the mqa switch is turned on, the x16 displays 44,1 khz pcm. When i turned it off it displays ofs 382 for ex whitch is correct for the second and third unfold.
    Anyway, thank you for your help.
  • ThierryB
    I noticed same thing.
    How do you explain it?
