Artwork Issues!!
Thank you Bjorn, but the BluOS cache is not located at the address indicated. I have no "AppData" directory as a subfolder in UserName, and a search reveals no BluOS Controller/Cache. Your initial suggestion (delete either Folder or Cover) does not work.
"AppData" is a hidden system folder, substitute with your "username" and paste in the address bar or enable viewing of hidden files and folders.
