I'm going Bluesound! Pulse 2 or 2i as a starter standalone?
    Hello,
    There are a few features added to the 21 generation Bluesound speaker. They are as follows:
    Two way Bluetooth functionality to connect to Bluetooth headphones or speaker
    Improved Bluetooth codec from aptX to aptX HD
    Support for the 5GHz wireless band
    Support for Apple's Airplay 2
    If you feel like these features would make for a much better experience, then go for the 2i. If you find you likely won't need most or all of these features, then the 2 would do just fine.
  • lylelovett
    Understood.
    If I have some Bluesound devices on 2.4GHz and others on 5Ghz, but all are still on the same network/domain:
    1.  Can they all still see each other?
    2.  Will I still be able to do multiroom-synced audio across them all
  • Sam R.
    The answer to both would be yes. Though I do usually recommend keeping the players on the 2.4 band as I do find its more reliable.
