Pulse soundbar+ & 2 x flex 2i not connecting automatically
2 Personen folgen
    Hi Kim
    Your Bluesound Players are designed to be always on and always ready. There is no need to turn them off.
    Every time you do so you are having to reconnect and renegotiate your home network.
    Rest assured we care about power consumption too. After 15 minutes of idle, all Bluesound Players enter stand by turning off the amplifiers and consuming less than 3W as required by EU energy conservation laws.
    Just leave them as is when not being used.
  • Kim Hoersted
    Ok. But I turn off soundbar because for normal tv I use sound from tv. And if I do not turn off soundbar tv gets confused.
  • Kim Hoersted
    Is it 3watt pr hour?
