Ethernet cable
Good morning, I have been looking for the perfect cable to run from my router to the node. What do you guys recommend ?
Thanks in advance, Chris
The one in the box is more than fine.
You will have no sonic performance or improvement of audio using any stock CAT 5e or CAT 6 ethernet cable. The data is merely 1s and 0s at that point.
