stuttering wired noise from one channel on Powernode
BeantwortetHi, I've started experiencing weird noises from one channel on my Powernode, and it's just the left channel (and not the speakers).
It starts as soon as Powernode turn on, so without opening the bluos app, but weirdly now when I open the bluos app and there's a change in track, it's accompanied by some scratchy noises as well.
I'd appreciate some help. Thanks
Yes it moved to the right speaker, so it's definitely the Powernode.
It does not help, I tried to reboot, tried to reboot my network, and reset my powernode 3 times.
I did send support request, her answer was to contact an Australian warranty service to sent it to them for evaluation (I bought the Powernode used).0 -
Not really, I can't use the warranty as I'm the second owner...
They won't honour the warranty as I'm the second owner, so I was hoping to find some solution on the forum :)
4 Kommentare
