Node + DenaFrips DAC + bluesound Pulse 2i + Flex 2i
  • Eric Cote
    I did not have this problem when I wasn't using the external Denafrips DAC. I used the Node internal DAC and the X3 DAC with no issues. As soon as I switch to the Denafrips DAC, i have a huge audio delay problem. The X3 is already set to direct bypass.
  • Eric Cote
    It's definitely when I use the Denafrips DAC that I start hearing audio delay with my other Bluesound speakers.
