Wired Subwoofer how to force wired conected subwoofer on bluesound rear node In a cinema setup with a powernode 330 in front as well ?
    Bjørn Ulvik
    Node is not compatible with "Home theater grouping".
    Use standard grouping, and make sure A/V mode is on.
  • Permanently deleted user
    Björn, tanks for the tip. I tested it and that works 😃Do you know if it is possible to setup a center speaker with a Bluesound speaker to get Dolby 5.1 this way?
