power off analogue source powernode
3 Personen folgen
    The POWERNODE will continue to detect signal from the turntable is the turntable has not shut down, so no.
  • James Connor
    So if I power off the turntable (which I need to do to stop the platter spinning) will it stop a signal being detected by the powernode and powernode will then go in to standby?
    Correct - if however you have any issues, in the Help menu of the BluOS App, select Send Support Request and our Support Crew can also help with that or any other matter you come across.
