Help! Vault 2i CD eject failed now light stays red
    Hi John
    Your VAULT is in upgrade mode. You can safely unplug it., wait 5 seconds, then plug it back in. If the CD does not eject or the LED does not return to solid blue within 30 seconds of rebooting, please e-mail support@bluesound.com and our  Support Crew will be happy to help.
