A few Vault 2 questions
Hi,
I have a few Vault 2 questions:
1. When ripping a cd is there anyway to see how much time is remaining?
2. When a cd has been ripped and the artist, album and tracks are saved as unknown - how can I edit this so it is correctly displayed and add cover art?
3. How can I delete an album from the library?
Thanks in advance.
Trae Hancock
Hi Seppi,
Great. Thanks. I use Bliss atm for another project. You originally suggested it to me and it works well.
I will have a look at the network share tonight. Thanks for the details and link..
Trae
If editing tracks metadata or deleting albums you need to run a “rebuild index” afterwards.
Rebuild index is not needed when deleting albums/tracks, a normal reindex is enough.
Changing folder, file-paths, etc. will also be covered by a normal reindex.
Changing metadata will also change the "date" of the file(s), so a normal reindex will also be enough.0 -
Thanks, Bjørn. I will look a bit closer at this tonight...
Trae
