Switching to analog input without using BlueOS app.
BeantwortetI have a Powernode 2i and I'm connecting my turntable to analog input 1. Is there a way to switch sources without using the BlueOS app? I would prefer to use the main unit if possible, but I can't seem to select the analog input in my presets.
As your device does not have physical preset buttons, the only way to switch sources on your POWERNODE 2i is through the BluOS app or with the use of the Bluesound RC1 remote control.
However, we would like to clarify that the RC1 remote control can only be used to switch between sources that have been set as presets in the BluOS app. Therefore, if you would like to switch to the analog input manually, this would not be possible using the remote control.
Hope this helps and thanks for #LivingHiFi
