Vault 2i wireless connection or RCA Interconnects
BeantwortetI had my Vault 2i connected with RCA interconnects to my previous integrated amplifier. I bought the NAD M10v2 and now I can play my Vault Library wirelessly or I could reconnect it with RCA interconnects to the back of the NAD.
My question: For the best sound quality should I use it wirelessly with the NAD or use RCA interconnects. The Interconnects are decent: (Audioquest Big Sur)
You can continue using your VAULT's library and play using the NAD M10 wirelessly.
Our products do not upsample/downsample and play audio formats it receives.
Hope this helps and thanks for #LivingHiFi -
Hi Mark T.
I appreciate your reply but I don't understand how the upsampling/downsampling capability answers my question. So simply, given a choice are you recommending wireless or high quality cables for the best sound quality on any given file format?
Thank you
Bill
