NAD C368+MDC BLUOS 2I - AIRPLAY PROBLEM
    Mark T.
    Sr. Support Crew Member
    Hi Roger,
    Try rebooting your entire network and see if that helps with your issue. If issue persists, please reach out to our support crew by sending a support request using the BluOS app or by emailing us at support@nadelectronics.com
  • John W
    Did you ever solve this? I'm having the same problem. I can play Bluetooth and Spotify. But can't Airplay anything. There's nothing in my Airplay menu to go to my NAD c368.
