Right settings for my audio setup with Node n130?
  • Mark T.
    Sr. Support Crew Member
    When using a subwoofer with a pair of Genelec G5 speakers, it is important to properly configure the crossover and low pass filter settings to ensure optimal performance and avoid any potential issues. Here is a suggested setup for your system:
    1. Set the SVS PB3000 subwoofer to "LFE mode active" in the SVS app. This means that the subwoofer will receive the dedicated LFE (low frequency effects) channel in multi-channel audio content.
    2. In the BluOS app, turn on the subwoofer output and set the crossover frequency to 60Hz. This means that the G5 speakers will handle frequencies above 60Hz, and the subwoofer will handle frequencies below 60Hz.
    3. In the SVS app, set the low pass filter to "off" when using the subwoofer with the LFE channel. This ensures that the subwoofer only plays the frequencies it is supposed to receive from the LFE channel.
    By following these settings, you should be able to achieve a proper integration between your Genelec G5 speakers and SVS PB3000 subwoofer. However, it's important to note that these settings may need to be adjusted based on your room acoustics, personal preference, and the specific content you're listening to. You can also experiment with different crossover frequencies and low pass filter settings to find what sounds best to you.
  • MRJP
    Thank you. So that's exactly what I thought. That LFE was just question mark for me. When LFE ON, low pass freq. is greyed out and vice versa.
