USB connection
BeantwortetHi,I'm using the USB port with an external DAC. (Node N130)
How could I use a HD for storage (or a simple USB pendrive) if this port is already busy?
Thank you Seppi,
I did it but I can't see the new hd connected to the zyxel router;any suggestion?
Dear Seppi,
I connected an HD to the router and shared it.
I can reach it through a PC but Node doesn't find it.
I did it without result
