The audio clips in PowerNode 2i and is connected via HDMI eArc cabel from a Samsung TV (model QE65Q90TATXXC)
BeantwortetI have problem with the audio when a Samsung TV (model model QE65Q90TATXXC) is connected to my PowerNode 2i, via a HDMI eArc cable. The the sound cuts irregularly when I am watching on the TV.
When I am using Spotity, the audio is perfect...
Someone who has the same problem?
Have you tried replacing the HDMI cable? Please confirm if the HDMI cable you are using is a "Certified HDMI Cable".
If you have checked this and still experiencing issues, please send a support request to support@bluesound.com or using the BluOS app and a member of our support team will be happy to assist you.
Thanks for #LivingHiFi -
Hi Jan,
Had similar issue and have been told to go in the TV audio settings and ensuring that the HDMI output is set to PCM/PCM Stereo format. That is because our Bluesound Players will only process/decode PCM/PCM Stereo audio format.
Hope that helps
