Bluesound powernode Edge. Possible to reverse physical controls ?
  • ThrawnJL
    Thank you very much for your answer :)
    Well remote is not something we are interested in since it’s place in our kitchen :) we don’t want remotes there and also then we can just use apps :)
    and the wall stuff is a great idea but not possible for us either :) (apartment , not enough room and 10 thumps :p)
    Maybe one could hope a firmware update could give the option unless it’s somehow hardcoded into the touch interface.
    For now we will just have to get used to the reverse direction or use app then :)
