NAD C658 SR9 remote replacement.
BeantwortetHi,
Where can I get a replacement for the NAD SR-9 remote that comes with the C658? It seems they don't exist anywhere!
Is there an alternative remote that will work just as well?
The RC1 is pretty expensive at £50, but I would consider it if that is the best option.
Thanks
0 Kommentare
