Battery Pack is stuck
BeantwortetHello,
I have my Pulse Flex for several years now. I have added a Battery Pack from the beginning (BP100).
Now I have a strange problem: the Battery Pack is stuck. I can't detach it from the Flex. Pressing the button won't help.
Do you have any suggestions how to solve this?
Many thanks!
Tom
I suggest bringing the device to your local dealer this way no further damage can happen to your device.
You can use the link below to look for a local dealer closest to you - Find A Store - Bluesound
Thanks for #LivingHiFi
