Pulse 2 low volume from digital/analog in?
BeantwortetA question to the community - do you experience a very large difference in volume level when switching from streaming (e.g. Spotify connect) to analog or digital in? In my case, the difference is almost tenfold (10% volume for music, needs to jump to 70 or even 100% for TV+AppleTV 4gen, PS3, 3.5mm from iPhone or Macbook). Changing settings on any of the devices doesn't seem to affect it, and the simplest case of iPhone with a stereo cable has the same effect (did it just as a control).
Thanx!
Hi Miro,
Volume levels will depend on the source as such volume levels will differ from source to source.
You can setup Presets to have a specified Volume for certain inputs and even Playlists, more information can be found here :
https://support.bluesound.com/hc/en-us/articles/209333728-How-Can-I-Set-a-Preset-in-Bluesound- -
I am also struggling with this on my Powernode 2i.
I'm struggling with this on my new Powernode. The volume of any inputs (a turntable in my case, but also confirmed with running my iphone via a jack) seem to be an order of magnitude lower than the internal streaming. This is really frustrating, as I have to nearly run the amp at full volume in order to hear my turntable, but then risk flipping back to internal streaming and blowing my head off.
I am seeing this too and I am wondering if there could be a input volume gain to adjust such situations. I saw such settings in many other systems.
If not possible by software for the 2i and newer devices maybe put this into newer devices, because this would really help.
4 Kommentare
