Problem USB connecting to DAC
    Hi Nils
    In reviewing the documentation of your third-party DAC, there is some language describing what is being done to the USB input on that device, and is handled significantly differently than traditional true audiophile connections such as digital coax.
    The USB input offers full high resolution support for all files up to PCM 32/768 and DSD256. Unwanted noise coming in through USB is double filtered to suppress them to a level where it can’t affect audio.
    This sounds like your DAC is not a pure DAC but is a digital-to-digital converter as well and maybe upsampling. If coax, which is always your best option, is not available then please reach out to a third-party DAC manufacturer as to why you are receiving audio distortion through the USB input of their device but not through COAX or TOSlink.
  • Klas
    Hi. You are not alone with this problem. Same with my Node Icon. HAve tried three different DAC:s. Same problem with all of them
