Why is connection still an issue ??
  • Ditlev
    Thanks for your replay, Seppi.
    But i've been through many routers, and i even logged on to the advance settings, and changed to static ip and 2,4 GHz just for the note to work, sadly with no results. I should not have to do this much tinkering in the first place, this was suppose to be a plug and play device. The problem is not the router - coz it works and all other devises works. The problem is that the Bluesound note 2 that i have is a shitty product in regards to connection. I dont know how the manneged to mess this up so bad and still not have released firmware to fix the issue. never had a problem using my app to remote control my Samsung tv. app to set up my car, app for a lot of random gadgets. Only the Bluesound note 2, hence the problem is not the router but the product.
    I tried the BluOS help some years back, i did all they aked me to, did not help. Problem is it is very hard to find a problem there is not there all the time. Sometimes a reboot doesn't even help and i just have to keep trying for days.
  • Ditlev
    Hi Alain.
    Thx. Good simple ide. I will try this out
