BluOS doesn't always choose the highest quality TuneIn stream
BeantwortetHi,
I have a TuneIn radio station added to a preset of my Bluesound Node. This station offers the following 3 streams:
128 kbps MP3 - 96% reliable
64 kbps AAC - 98% reliable
64 kbps HLS - 25% reliable
It seems that when I choose the preset BluOS choose the 64 kbps AAC stream. Maybe because this is the most reliable, but I prefer the highest bitrate stream which is in this case only a fraction less reliable.
Is there a setting for this? Or do I have to save the preset in an other way?
Correct - BluOS will select the most reliable stream. You will have to manually select different streams as this is not programable.
Well, I tried: when I select the prefered stream and after that I add the station to a preset, next times it will always choose this prefered stream when I click the preset. So in that way it is programable!
2
