Best way to connect to KEF LS50’s and Vanatoo Transparent Zero??
BeantwortetHi—I have a pair of KEF LS50 Wireless speakers (non-meta), which are also connected to a channel switch that is connected to a preamp/turntable, and also a pair of Vanatoo Transparent Zero speakers that I want to use with a new tv.
Can anyone offer advice as to how to connect a Powernode or a Node 2i in either setups since the speakers are active in whatever way will maximize audio quality? I use Tidal Hi-fi and would like to maximize the MQA feature if I can. Both pairs of speakers have have optical, coax, and aux as wired input options. I also need to ensure for the Vanatoos that I don’t get dialogue delays (I know I can get a Bluetooth connection from the tv to the bluesound and then connect to the speakers without delay but, um, it’s Bluetooth).
Thank you so much! I’ve been wracking my brain over this and realized I need some help.
Dan
Hi Dan
Since these are active speakers, you would be looking at a NODE rather than a POWERNODE. You would be looking at one NODE per pair of active speakers. Check out www.blueosund.com/stores to locate an authorised dealer near you to go through your specific requirements and find a solution that works best for you.
