Node + AVR Pure Direct + Subwoofer signal
  • Mario Caires
    Thank you Seppi! ;)
    The KC62 has 2 line inputs (LFE and Smart-Connect), I am testing both with my AVR and it seems it works with either one, not sure what's the difference between both though... My ideia atm is to use the smart-connect to the AVR and the LFE to the Node. This way I don't have to disconnect cables when I want to use the sub with the AVR or with the Node...
    Another question, given that I will connect the Node to my AVR through analogue RCA, so I can use Node's DAC and put the AVR in Pure Mode, would I benefit in buying a PowerNode instead? Is there any advantage in this regard?
  • Mario Caires
    Got it! Makes sense...
    Will go with a Node then!
    Many thanks!
