Bluesound RCA output clock?
    Hi Sal
    You should not be connecting analogue to an external DAC. You are then performing multiple conversions from Digitial to analogue back to digital and then back to analogue. When using the digital out of the NODE, you are bypassing any digital signal processing on the 24/192 DAC of your NODE.
